Max Tension Force on Horizontal Rope Pulling 10kg Wood Sled
  • Thread starter Thread starter Comtrend
    Friction Tension
The discussion centers on calculating the maximum tension force in a rope pulling a 10kg wood sled with a box on a frictionless surface, ensuring the box does not slip off. It emphasizes the need for the coefficient of static friction between the box and sled to determine the maximum static friction force. Participants clarify that if the tension exceeds this frictional force, the box will slide off the sled. A calculation example suggests that with a static friction coefficient of 0.3, the maximum tension can be determined as 14.72N. The conversation highlights the relationship between tension, frictional force, and the masses involved in the system.
Comtrend
I have a question where a horizontal rope pulls on a 10kg wood sled over a frictionless surface. On that sled is a wood box. It is asking what the largest tension force in the rope would be where the box doesn't slip off.
Air resistance/Drag is neglected. Wouldn't the box remain on the sled indefinetely as long as it didn't accelerate to fast? If not then I would use the coefficient of static friction right?
Comtrend said:
I have a question where a horizontal rope pulls on a 10kg wood sled over a frictionless surface. On that sled is a wood box. It is asking what the largest tesion force in the rope would be where the box doesn't slip off.
You would need to know the coefficient of static friction between the box and sled to find the maximum static friction force. That is the maximum force that the sled can apply to the box. If the tension exceeds that force, the box will slide off.
AM
Andrew is right, you need the frictional force between the sled and the box.
for the box:
F_f=m_{box} a
and for the sled
F-F_f=m_{sled} a
As we can see, we have 3 unknows and only 2 eqs. So you must provide some information about the friction at the contact surface.
I got 14.72N with a coefficient of static friction of 0.3. So is the Ff equal to the force of Tension because the sled is on a frictionless surface?
So then Tension equals 14.72N?
For force of friction for the box I used F_f=mN
I don't know how to get mew so it is just an m.
The tension you need is F (in my eqs). F_f (the frictional force) and F (the tension in the rope) are different.
You have to find F from the eq. below:
\frac{F-F_f}{F_f}=\frac{m_{sled}}{m_{box}}
and you'll obtain the tension in the rope.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
