Engineering Max Voltage Across Capacitor & Resistor in a Circuit
The discussion focuses on determining the maximum voltages across a capacitor and resistor in a circuit driven by a periodic voltage source defined by V_s(t) = ∑_{−∞}^∞ (−1)^{n}g(t−nT), where g(t) = 7[u(t)−u(t−T)]. The voltage source produces a pulse train with an amplitude of ±14 Volts. The voltage across the capacitor varies symmetrically about zero volts, with the maximum voltage occurring just before the input transitions from +E to -E. The solution involves applying Kirchhoff's Voltage Law (KVL) and solving a differential equation for the capacitor voltage.
  • Understanding of periodic voltage sources and pulse trains
  • Familiarity with Kirchhoff's Voltage Law (KVL)
  • Knowledge of differential equations in electrical circuits
  • Concept of transient analysis in capacitive circuits
  • Study the application of Fourier series in analyzing periodic signals
  • Learn about transient analysis techniques for capacitors in circuits
  • Explore differential equations related to capacitor voltage behavior
  • Investigate the effects of varying input voltages on capacitor and resistor voltages
Electrical engineering students, circuit designers, and anyone involved in analyzing transient responses in capacitive circuits will benefit from this discussion.
GalMichaeli
For the circuit in the picture below, with V_{c}(t=0) = 0 and a voltage source with period T described by
V_s(t) = \sum_{-\infty}^\infty (-1)^{n}g(t-nT)
where
g(t) = 7[u(t)-u(t-T)]\quad [Volt]
and u(t) is a step function described by
<br /> u(t) =<br /> \begin{cases}<br /> 1 &amp; \text{if } t \geq 0 \\<br /> 0 &amp; \text{if } t &lt; 0<br /> \end{cases}<br />
What is the maximal voltages across the capacitor?
What is the maximal voltages across the resistor?
The voltage source is a pulse train with amplitude \pm 14 \quad [Volts] and since at time t = 0 we may consider the cap. as a short-circuit, we have V_{R}(t=0) = 14 \quad [Volts].
I'm having trouble figuring out what the maximal voltage across the cap. is.
Should I apply transient analysis?
Thanx.
First, never mind the voltage anywhere at t=0. You don't know what t=0 is. This voltage wavetrain has been running since t = -∞.
Now my gut reaction was Fourier series. But that's the hard way. Instead:
1. realize that v(t), the voltage across C, will vary symmetrically about zero volts since that is the average value of your input, from Vmin to Vmax = |Vmin|.
2.Then realize that the most negative C voltage is just before the input goes from -E to +E (why?). Then realize by symmetry that the max C voltage will occur just before the input transitions from +E to -E (again, be able to justify this statement).
3. Write the KVL: current thru R = current into C starting with t=0 at the -E to +E input transition. This will be a differential equation, easy to solve, in capacitor voltage v(t). Solve with the initial condition v(0+) = Vmin, then solve for v(T) = Vmax. The rest should "follow immediately" as the textbooks say.
  • · Replies 17 ·
