Maxima/Minima of extrema function f(x,y)=x
  • Thread starter Thread starter RyanV
    Extrema Function
RyanV
Find the extrema of the function subject to the given constraint.
f (x, y) = x
x2 + 2y2 = 3
det = fxx * fyy - (fxy)2
If det > 0,
fxx < 0 \Rightarrow MAXIMUM
fxx > 0 \Rightarrow MINIMUM
If det < 0,
\Rightarrow SADDLE POINT
If det = 0m
Inconclusive
I appear to be struggling with this maxima/minima stuff. Previous questions were just correct. I had to look at the book's answers to figure a way there. I seem to be missing something...but here is my attempt:
Since x2 + 2y2 = 3,
x = \pm\sqrt{3 - 2y<sup>2</sup>}
Therefore,
f(x, y) = \pm\sqrt{3 - 2y<sup>2</sup>}
At critical point,
\nabla f = (0, - \frac{2y}{\sqrt{3 - 2y<sup>2</sup>}} )
= (0, 0)
Therefore, equating gives
0 = 0
- \frac{2y}{\sqrt{3 - 2y<sup>2</sup>}} = 0
So extrema points at (\sqrt{3}, 0) & (-\sqrt{3}, 0) since y = 0.
To find max/min/saddle, find det.
fxx = 0
fxy = 0
det = 0 * fyy - (0)2
det = 0
Which is inconclusive. The book has (\sqrt{3}, 0) as a maximum and (-\sqrt{3}, 0) as a minimum.
I don't know what I'm missing out here...
Thanks in advance.
f (x, y) = x
x2 + 2y2 = 3
If det > 0,
If det < 0,
If det = 0m
Inconclusive
Since x2 + 2y2 = 3,
Tip: Don't mix [ sup] or [ sub] tags inside [ tex] tags. Instead use ^{} for exponents and _{} for subscripts.
RyanV said:
Therefore,
At critical point,
= (0, 0)
0 = 0
I don't see how the equation above is helpful at all.
fxx = 0
fxy = 0
det = 0
Thanks in advance.
What I think you are missing is some understanding of what f(x, y) = x looks like, which is a plane. Since a plane is a flat surface with no curvature, there are no dips or bumps. Also, since the domain of this plane is restricted to {(x, y) | x2 + 2y2 = 3}, any maximum or minimum points are attained at points the farthest away from the origin.
Ohh...I see... I feel so silly ><
Thanks a lot for that.
If I may, I have another question regarding maxima and minima...
Find local minima, maxima and saddle points of the function:
f(x, y) = (x2 + 3y2) e1-x2-y2
I started off finding the partial derivatives of x and y respectively and got:
fx = 2xe1-x2-y2 ( 1 - x2 - 3y2 )
fy = 2ye1-x2-y2 (3 - x2 - 3y2 )
At critical points, (fx, fy) = (0, 0)
Equating gives,
2xe1-x2-y2 ( 1 - x2 - 3y2 ) = 0 --- (1)
2ye1-x2-y2 (3 - x2 - 3y2 )= 0 --- (2)
After that I'm kinda lost...I slithered my way to get (0, 0) but very unconvincingly. I would rather have some solid reasoning as to why.
Like I mentioned earlier, I think I'm missing some understanding and maybe that's why I'm not getting this.
The answers give
Min at (0, 0),
max at (0, 1), (0, -1),
saddle at (-1, 0), (1, 0)
Thanks!
f(x, y) = (x2 + 3y2) e1-x2-y2I started off finding the partial derivatives of x and y respectively and got:
Equating gives,
The answers give
Min at (0, 0),
When you have a product equal to 0, then one of the factors must be equal to 0. For instance, from this equation
2xe^{1-x^2-y^2}(1-x^2-3y^2) = 0
you can conclude that x=0 or 1-x2-3y2=0. Similarly, the other equation gives you y=0 or 3-x2-3y2=0. Now you just have to find the solutions for all four possible combinations:
(1) x=0, y=0;
(2) x=0, 3-x2-3y2=0;
(3) y=0, 1-x2-3y2=0; and
(4) 1-x2-3y2=0, 3-x2-3y2=0.
Ooo, I see now. I think I managed to confuse myself by using how for eq (1),
since x = 0,
1-x2-3y2=0
1 - 3y2 = 0
which is definitely not looking good in terms of the answers. But I understand now =)
One last thing, so for the 4th solution: (4) 1-x2-3y2=0, 3-x2-3y2=0.
There isn't a solution for this yeah? Since all the variables x/y cancel out.
since x = 0,
1-x2-3y2=0
1 - 3y2 = 0
Right idea, but wrong equation. That's the one that has to hold if y is 0 and x isn't 0.
Yup, that combination has no solutions.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
