Maximizing Area with a 10m Wire: Square or Equilateral Triangle?
  • Thread starter Thread starter Greywolfe1982
    Area Maximum Wire
Greywolfe1982
How do you cut a 10m piece of wire to get the maximum area when forming a square and an equilateral triangle?
asquare=s2
atriangle=s2*\sqrt{}3/4
(Note that I've already found the total area function, its derivative, its critical points and that x=~8.73 is a minimum.) As far as I know, the maximum area comes from not cutting the wire at all and making a triangle. Using those area formulas, it gives an area of ~43.3m2. However, the back of the book says maximum area comes from making a square. But doesn't this only give an area of 6.25m2? (s=10/4m, s2=6.25m2) Is the book wrong, or am I overlooking something?
Your formulae were correct, but you must've plugged the wrong value of s in when calculating the area of the triangle. Since it's an equilateral triangle, s=10/3 and plugging this into the triangle area formula A=\frac{s\sqrt{3}}{4} gives A\approx 4.8 which is less than the area of the square.
You might find this interesting to note, if you consider a circle as being a regular polygon with infinite sides, then for any given perimeter P, the more sides the polygon has, the larger its area. For example, an equilateral triangle with perimeter P (each side P/3) has less area than a square with sides P/4 each, which is less than a pentagon... etc. and the circle with perimeter P has the largest possible area.
Aww. You beat me to it.
I was in the shower when I realized I used 10 as a side instead of 10/3. I haven't worked it out yet, but I'm assuming I won't have any problems from here. Thanks for the response.
Ahh that shower... we'd still be counting with our fingers if it weren't for that invention :wink:
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
