Maximum charge differential equation
greg997
Hi, I am having a small problem with this equation
Charge Q=t^3+5t^2+10t+130
What is the maxiumum charge?
If I differentiate with repect to time, at t=6, for example then I have value of current flowing at that time.
What is the maximum charge then? I don't understand the question. Do I need to differentaite it again? Thanks
At maximum Q, dQ/dt = 0.
But, so long as there is no mistake in the equation given, there is no value of t for which dQ/dt = 0.
The equation has some value changed by me, but if dQ/dt=0 then the current is 0. Is that right?. About the equation, if I differentiate Q, then I can have two roots t. If I substitute them in the Q equation I have two real, different values. Is that right? Do I choose the higher value obtained?
A quadratic equation can have 2, 1, or no real roots. Read what grzz said again. Are there limits on the values of t?
No, there are no limits.I know that quadratic equation can have 2,1, or no ral roots. But in this case it has two different real ones.
Each term on the right hand side increases with time, and these are all summed. So Q continuously increases with time. It will reach a maximum only at the end of time.
I think it's worth taking another look at the question. Something might be amiss.
What is the maximum charge?
If I differentiate with respect to time, at t=6, for example then I have value of current flowing at that time.
What is the maximum charge then? I don't understand the question. Do I need to differentiate it again? Thanks
It asks for maximum charge, so just differentiate once. Yes, it so happens that when dQ/dt = 0 , in addition to having maximum (or minimum) charge, the current is also zero, because current = dQ/dt .
