Max Distance Mass M Can Be Placed Before Wire Breaks
  • Thread starter Thread starter melissa_y
    Maximum
The maximum distance from the wall at which mass M can be placed before the wire breaks is 1.5 meters. This calculation considers the forces acting on the system, including the weight of the bar (233 N) and the mass M (384 N). The wire can withstand a maximum tension of 547 N, which is determined using trigonometry and equilibrium conditions. The tension in the wire at the maximum distance is calculated to be 731 N, leading to the conclusion that any distance greater than 1.5 m will exceed the wire's capacity. This analysis assumes ideal conditions without friction or external forces.
melissa_y
A uniform horizontal bar of length L = 5 m and weight 233 N is pinned to a vertical wall and supported by a thin wire that makes an angle of theta = 43o with the horizontal. A mass M, with a weight of 384 N, can be moved anywhere along the bar. The wire can withstand a maximum tension of 547 N. What is the maximum possible distance from the wall at which mass M can be placed before the wire breaks?
:: Use Equilibrium condition ::
To determine the maximum distance from the wall at which mass M can be placed before the wire breaks, we need to consider the forces acting on the system. The weight of the bar and the mass M will create a downward force, while the tension in the wire will create an upward force.
First, we need to find the tension in the wire at the maximum distance. We can use trigonometry to determine that the horizontal component of the tension is Tcos(theta), where theta is the angle between the wire and the horizontal. Plugging in the given values, we get Tcos(43) = 547 N. Solving for T, we get T = 547 N / cos(43) = 731 N.
Next, we need to find the distance from the wall at which the tension in the wire is equal to its maximum capacity of 547 N. This can be done by setting up an equation that equates the tension in the wire to the weight of the bar and the mass M. We know that the weight of the bar is 233 N, and the weight of the mass M is 384 N. So, the equation becomes:
T = 233 N + 384 N
Substituting the value of T we found earlier, we get:
731 N = 233 N + 384 N
Solving for the distance, we get:
d = (731 N - 233 N) / 384 N = 1.5 m
Therefore, the maximum possible distance from the wall at which mass M can be placed before the wire breaks is 1.5 m. Any distance greater than this will result in a tension in the wire that exceeds its maximum capacity of 547 N, causing it to break. It is important to note that this maximum distance is only valid if the bar and the wire are ideal and there is no friction or other external forces acting on the system.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
