Maximum height reached by a projectile
To determine the maximum height reached by a projectile, integrating the velocity function v(t) to find the position function y(t) is essential. The kinetic energy (KE) and potential energy (PE) method is not applicable due to air drag affecting the projectile's motion. Instead, the maximum height can be found by analyzing the conditions for the maximum of y(t). Understanding the relationship between velocity and position is crucial in this context. Proper application of calculus will lead to the solution for maximum height.
sid9221
http://dl.dropbox.com/u/33103477/gravity.png
I have worked out the first two bits. (So you can assume that I have that) But I can't figure out how to work out the maximum height reached.
I know there I can equal the KE and the PE to work out max height, but that doesn't look like it'll work here.
Integrate v(t) to find y(t).
The KE/PE argument will not work because of the presence of air drag. However, you don't need it. You have v = dy/dt. Do you recall the conditions for a maximum of y(t)?
RGV
