Maximum Load question given Safety factor
The ultimate strength of the round steel rod is 620.000 MPa, and with a required safety factor of 3.000, the maximum permissible load can be calculated by dividing the ultimate strength by the safety factor. The diameter of the rod is 3.000 cm, which allows for the calculation of the cross-sectional area using the formula for the area of a circle. The maximum load is then determined by multiplying the allowable stress by the cross-sectional area. The user initially sought help but later indicated they solved the problem independently. This illustrates the importance of understanding safety factors in engineering applications.
bad at math gu
Could i get some help with this one please
The ultimate strength of a round steel rod is 620.000 MPa. If a factor of safety of 3.000 is required, what is the maximum permissible load for the rod if it has a diameter of 3.000 cm?
Show your work :smile:
:D nvm i just got it
