Maximum Power dissipated at load resistor
  • Thread starter Thread starter Bling Fizikst
    Power Resistance
Maximum power is dissipated when the load resistance equals the Thevenin resistance, following the formula P ≤ V_th² / 4R_th. The discussion involved applying a star-delta transformation and using the loop current method to derive expressions for current and Thevenin voltage. Confusion arose regarding the treatment of the battery and the internal resistance in the circuit. It was clarified that the battery should be short-circuited rather than removed, which led to the correct calculation of Thevenin resistance. The participant corrected their mistake and successfully arrived at the right answer.
Bling Fizikst
refer to the image
refer to the image
So , max power is dissipated when the load resistance and thevenin resistance becomes equal such that $$P\leq \frac{V_{\text{th}}^2}{4R_{\text{th}}}$$
Then i applied the 'star delta' transformation by converting the 'delta' ABC to 'star' ABC .
From there , by loop current method , i got $$i=\frac{\epsilon}{\frac{5R}{3}+r}$$ (assuming the other ##\frac{R}{3}## is redundant)
Hence, $$V_{\text{th}}=i\cdot \frac{R}{3}=\frac{\epsilon R}{5R+3r}$$
Now , by removing the battery ##\epsilon## , i got ##R_{\text{th}}=\frac{5R}{3}+r##
Computing , ##P_{\max}## using these values gives the wrong answer . Not sure where i went wrong . I have confusions regarding the value of ##V_{\text{th}}## though
Is ##r## a resistor??? IDK, it's strange to see two batteries in series if they aren't modeling something about two different batteries. It's even stranger to use that schematic symbol for a resistor. I'd guess it's a battery (ideal voltage source, really).
You don't remove the battery, you short-circuit it, i.e. replace it with a wire. Then you find the resistance between the load terminals. Check you have done this correctly.
Edit. To be more precise, I should have said short-circuit the emf: the battery's internal resisstance should still be part of the circuit - it doesn't get shorted-out.
Yeah!!! i made that silly error of replacing the battery with open circuit . I have arrived at the correct answer now . Thanks!
Likes Steve4Physics and berkeman
