Maximum voltage in the primary circuit of a transformer
The maximum voltage in the primary circuit of a transformer with 240 windings and an area of 10 cm² is calculated to be approximately 4.9 V. The effective voltage derived from the induced voltage equation is 3.12 V, leading to a maximum voltage of 4.4 V using the formula Vmax = √2 * Veff. The discrepancy arises from the sinusoidal nature of the alternating current, where the peak voltage is determined by V0 = N * B0 * S * ω, resulting in the correct maximum voltage of 4.9 V. Understanding the relationship between the magnetic field and induced voltage is crucial for accurate calculations.
  • Understanding of Faraday's Law of Electromagnetic Induction
  • Knowledge of sinusoidal functions and their derivatives
  • Familiarity with transformer design principles
  • Basic concepts of alternating current (AC) circuits
  • Study the derivation of Faraday's Law in detail
  • Learn about the characteristics of sinusoidal waveforms in AC circuits
  • Explore transformer efficiency and losses in electrical engineering
  • Investigate the role of inductance in AC circuits
Electrical engineers, physics students, and anyone involved in the design or analysis of transformer circuits will benefit from this discussion.
lorenz0
The primary circuit of a transformer has ##N=240## windings, each one with area ##S=10cm^2##. In the primary circuit flows a sinusoidally alternating current. The magnetic field in the iron core of the transformer goes from the maximum value of ##B_0=65mT## along the direction perpendicular to the windings to the exact same value but in the opposite direction in ##\Delta t=10 ms##.
Find the maximum voltage in the primary circuit.
##V=-N\frac{d\phi(\vec{B})}{dt}##, ##V_{max}=\sqrt{2}V_{eff}##
The alternating current will create an induced voltage given by ##V=-N\frac{d\phi(\vec{B})}{dt}=-N\frac{\Delta\phi(\vec{B})}{\Delta t}=N\frac{2 B_0 S}{\Delta t}=\frac{240\cdot 2\cdot 65\cdot 10^{-3}\cdot 10\cdot 10^{-4}}{10\cdot 10^{-3}}=3.12 V## and since this is the effective voltage, the maximum voltage will be ##V_{max}=\sqrt{2}V_{eff}=\sqrt{2}\cdot 3.12 V\approx 4.4 V##. Now, the result given is ##4.9 V## but I haven't been able to figure out where I have made a mistake so I would be grateful if someone could point it out to me, thanks.
lorenz0 said:
Homework Statement: The primary circuit of a transformer has ##N=240## windings, each one with area ##S=10cm^2##. In the primary circuit flows a sinusoidally alternating current. ...
You seem to do ##\Delta \Phi/\Delta t## as if it were a sawtooth ...
Ah, I think I have understood now. Since ##V(t)=V_0\sin(\omega t)## it must be that ##B(t)=B_0\cos(\omega t)## with ##\omega=2\pi f=\frac{2\pi}{T}=\frac{2\pi}{2\delta t}=100\pi\ \frac{rad}{s}## so that ##V(t)=V_0\sin(\omega t)=-N\frac{d\phi(\vec{B})}{dt}=-N\frac{d}{dt}\left( B_0\cos(\omega t)S )\right)=NB_0S\omega\sin(\omega t)## thus ##V_0=NB_0S\omega=240\cdot 65\cdot 10^{-3}\cdot 10^{-3}\cdot 100\pi\ V\approx 4.9\ V.##
