Measurable consequences of entropy of mixing
The discussion revolves around the entropy of mixing, particularly the differences between distinguishable and indistinguishable gases. It questions whether a macroscopic experiment can differentiate between a pure gas and a mixture of distinguishable particles without prior knowledge of their differences. The conversation highlights that distinguishing gases requires specific methods, such as semipermeable membranes or variations in molecular weight. The solution to Gibbs' paradox is mentioned, which involves assigning entropy to the information about distinguishability. The participants express a shared challenge in fully grasping the implications of these concepts, acknowledging the complexity of the topic.
crossword.bob
Most textbooks include an example of entropy of mixing that involves removing a partition between two (in principle) distinguishable gases, and compare this to the case where the two gases are indistinguishable. What I’ve not yet been able to figure out is what the consequences of this additional entropy are for the distinguishable case.
Say you are given two cylinders; one filled with a pure gas, and the other a mixture of two distinguishable (in principle) particles. Is there a macroscopic experiment you could perform to determine which is which, without knowing how the distinguishable particle types actually differ from each other? Do (for example) heat capacities depend on total entropy, so that one could measure temperature versus heat input for each cylinder?
Science news on Phys.org
No, you need some means to tell the two gasses apart, e.g. a semipermeable membrane, different molecular weight, so they can be separated.
The solution of Gibbs' paradox (which is the experiment you describe) consists of assigning entropy to *information*- information about distinguish-ability, for example.
http://bayes.wustl.edu/etj/articles/gibbs.paradox.pdf
Likes crossword.bob and Stephen Tashi
Thanks, that helps. I suspect it will take a little time for me to fully digest that paper, but there is some solace is knowing the problem that’s been bothering me has bothered better minds than mine in the past!
