Measure direction of subpicoamp current
Measuring the direction of subpicoamp currents is feasible, particularly in the femtoampere range, using specialized commercial instruments that can detect currents below a picoampere. The measurement method often involves translating current into voltage through a high impedance, though this approach has limitations due to factors like Johnson noise. Instruments such as those from Keithley provide practical solutions for these measurements. Additionally, resources from Analog Devices and Texas Instruments offer further insights into best practices and device specifications. Accurate measurement depends on the impedance used and the specific conditions of the setup.
swooshfactory
Is it possible to measure the direction of a current at current magnitudes this small? Or only its magnitude?
Measure using what method.
It is possible to measure the direction of currents to ground in the femtoampere range.
There are many commerical instruments that can go well below a pA
See e.g.
http://www.keithley.com/products/dcac/sensitive/lowcurrent/?mn=6485
This is from the point of view of the user no different than using a multimeter.
Note that how well you can do this will depend on the impedance, it is possible to measure very small currents if you somehow can "translate" your current into a voltage via a (large) impedance (but there are limits to how this can be done, e.g. the Johnson noise of the impedance).
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
