Measure of the smallest angle in the triangle
The problem involves finding the smallest angle in a triangle where two sides measure 6 centimeters and 10 centimeters, and the included angle measures 80 degrees. The context is rooted in trigonometry, specifically the application of the Law of Cosines and the Law of Sines.
  • Mixed
  • Participants discuss the use of the Law of Cosines and the Law of Sines to find the unknown angles. There is some uncertainty about how to apply these equations correctly, with one participant suggesting to first find the third side using the Law of Cosines before determining the angles.
Several participants are exploring different methods to approach the problem, including the Law of Sines and the Law of Cosines. There is a mix of attempts to clarify the equations and their applications, with some participants expressing uncertainty about the calculations. Guidance has been offered regarding the need to ensure calculations are in the correct mode (degrees or radians).
There is an indication that the original poster may be required to use specific methods as per homework guidelines, which could influence the approach taken in the discussion.
priscilla98
In a triangle, two sides that measure 6 centimeters and 10 centimeters form an angle that measures 80 degrees. Find to the nearest degree, the measure of the smallest angle in the triangle.
A2 = B2 + C2 – 2bc Cos A
I tried using this formula to get the answer but it didn't work out. This is one of the questions from the algebra 2 trigonometry regents. I know the answer which is 33 degrees but I don't know on how to get to that answer.
I think relevant equation would actually be
[tex]\frac{a}{sinA} = \frac{b}{sinB} = \frac{c}{sinC}[/tex]
along with the equation you've mentioned
Okay, then a = 6, b = 10 and C = 80 degrees, right? Then idk how to use the revelant equations you implied.
i just edited my reply. use your equation first and find c. Then use my equation to get A and B
Can you show us your work? Because I was able to get the answer (approx 33.409°). Make sure you are in degree mode when doing your calculations (or convert the 80° to radians).
Perhaps using the Law of Sines will work, but the OP may be required to use Law of Cosines for this problem.69
EDIT: Too slow ^.^
Thanks a lot praharmitra for this. I really appreciate it.
Actually, if you're not sure about the sine law, you can solve it using sin, cos and tan in right-angled triangles (draw the triangle, call its height h and relate it to the sine of 80 degrees, then divide the side of length 10 into two pieces of length L and 10 - L and relate L to the cosine of 80 degrees).
first you need to find side c using cosine law c2=a2 +b2=2abcosC
then use sine law to find angle A, cause the higher angle, the longer the side, since side A is the shortest, which means angle A is the smallest.
  • · Replies 19 ·
  • · Replies 22 ·
20K
