Measure the volume of a lighter than air balloon
To calculate the volume of a partially inflated helium balloon, known variables include the volume and initial and final pressures of the helium storage tanks. The balloon's internal pressure, temperature, and whether it is elastic or slack are crucial for accurate calculations. Two methods are suggested: weighing the helium tanks before and after filling the balloon to determine the amount of helium transferred, or using the ideal gas law (PV=nRT) to relate pressure changes in the tanks to the volume of helium in the balloon. The discussion emphasizes the importance of understanding the balloon's conditions to ensure accurate volume measurement. Proper application of these methods will allow for the desired volume percentage to be confirmed without fully inflating the balloon.
psuedoben
hello, i am trying to calculate the volume of a balloon (which is quite large). It has been filled with helium via a valve connecting helium storage tanks to the balloon. The knowns I have are the volume of the storage tanks, the intital pressure in the tanks, and the final pressure in the tanks after filling the balloon. I am confident there are enough knowns here to solve this problem and my gut feeling is that its a pretty straightforward solution too. despite this, i cannot seem to solve it.
Measure the balloon ?
I'm sorry Nidum, I suppose I left out a key detail. I don't want to fully inflate the balloon. I want to inflate it to a percentage of its maximum volume and then confirm that I've achieved that percentage by doing this calculation
What is the pressure in balloon? Is the balloon envelope elastic and under tension with greater than atmospheric pressure, or is the balloon a bag with a slack surface at 1 atm?
What is the balloon temperature? As He is transferred it will cool, so volume will be less until it equilibrates.
Is the pressure in the cylinder measured absolute or gauge, above atmospheric?
Method 1.
You could weigh the cylinders, fill the balloon, then weigh the cylinders again. The weight reduction will give the moles of He transferred. Convert moles to volume at balloon temperature and pressure.
Method 2.
Absolute pressure in cylinders will be proportional to helium content. PV=nRT.
Pressure reduction will give moles of He transferred = volume of balloon, adjusted for pressure and temp.
Likes psuedoben
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
