Mech E specializations: Thermal/Fluids vs Advanced Dynamics/controls
  • Thread starter Thread starter CaliStudent
    advanced
When choosing a specialization for a Master's in Mechanical Engineering, Thermal/Fluids and Advanced Dynamics/Controls both offer unique opportunities. Thermal/Fluids tends to be more applied, focusing on real-world systems, while Advanced Dynamics/Controls leans towards theoretical concepts and complex system behaviors. Job prospects vary, with Thermal/Fluids often linked to industries like energy and HVAC, whereas Advanced Dynamics/Controls is crucial in robotics and automation. Continuous learning is emphasized, suggesting that practical experience can enhance understanding in either field. Ultimately, the choice should align with personal interests and career goals.
CaliStudent
Which one would you choose for a MS concentration? And which field would be more theoretical and have more opportunities? sorry if I posted this in the wrong forum.
Do whichever you think is interesting. FWIW I've taught myself about 3 out of those 4 in the course of an engineering career. Your learning doesn't stop when you get your degree certificate!
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
