Medical supplies dropped from a plane (projectile motion)
The discussion centers on the physics of dropping medical supplies from a plane at an altitude of 150m while traveling at 40m/s. The pilot cannot drop the supplies directly above the campsite because they will land 220m away due to the time it takes for the supplies to fall. Calculations show that the supplies should be released 220m ahead of the campsite to ensure they land accurately. The participant confirms their understanding that waiting to drop the supplies directly above would result in them missing the target. Overall, the calculations effectively address both parts of the homework question.
Humbleness
A plane is to be used to drop emergency medical supplies (encased in a crash-proof container) to campers in Northern Ontario. The campers are in a clearing. The plane will approach the clearing at an altitude of 150m while flying level at 40m/s.
a) Why can't the pilot wait until the plane is directly over the campsite before dropping the supplies?
b) How far (in meters) ahead of the campsite should the supplies be dropped? Justify your choice.
Δdv= 1/2 aΔt2 - To find how long until the supplies hit the ground.
horizontal displacement = horizontal velocity which is 40m/s x Δt - To find how far horizontally would the supplies travel after being released from the plane
I will first start with b)
So I used the formula:
Δdv = 1/2 aΔt2
150m [down] = 1/2 (9.8m/s2 [down]) Δt2
Δt2 = 150 : 4.9 = √30.6
Δt = 5.5sThen I used the horizontal velocity of 40m/s x 5.5s (the time), to get the answer to horizontal displacement:
40m/s x 5.5s = 220m
So the supplies should be dropped 220m ahead of the campsite. This means that both the plane and the supplies themselves will be at 220m ahead of the campsite at the same time. Am I correct with this part, at least? I would really appreciate a confirmation.
For a) I tried drawing a diagram to show the airplane directly above the campsite, and then tried to draw a triangle, so that perhaps using trigonometry I could find out why the pilot shouldn't drop the supplies when directly above the campsite. But I am still not understanding how to even begin the calculations, using what equation... My main concern is that I am not understanding how to get to the answer to part a. How do I calculate what would happen if the plane dropped the supplies when directly above the campsite? I don't understand.
Hi Humbleness and welcome to PF.
You have already calculated that in part (b). When the package is released, it will land 220 m horizontally away from the drop point whether there is a campsite directly below or not. This, of course, assumes your calculation of 220 m is correct.
Likes Humbleness
Thank you kuruman for the welcome and quick response! I really appreciate it.
So then, my calculations answered both a and b? I am confused in that case as to how I would vindicate my response to question a. What exactly is it asking of me?
40m/s x 5.5s = 220m
Yes, this is correct, and hence question (a) is answered :) This shows that if you wait for the stuff to be dropped directly above, the supplies will land 220m away from the campsite
Likes Humbleness
Understood clearly now. Thank you so much for helping me clarify the confusion!
Likes Alloymouse
