Merry-go-round angular momentum conservation?
In summary, a 23 kg child hops onto a playground merry-go-round with a radius of 1.20 m and moment of inertia of 230 kgm2, rotating at 10.0 rev/min about a frictionless vertical axle. The moment of inertia of the system is 257.6 kgm2, and using conservation of angular momentum, the new angular speed of the merry-go-round is approximately 8.75 rev/min.
Jacob87411
171
A playground merry-go-round of radius R = 1.20 m has a moment of inertia I = 230 kgm2 and is rotating at 10.0 rev/min about a frictionless vertical axle. Facing the axle, a 23.0 kg child hops onto the merry-go-round and manages to sit down on its edge. What is the new angular speed of the merry-go-round?
Little bit of a problem with this one. How does the moment of inertia change when the 23 kg child steps on...Do you need to use angular momentum conservation?
Treat the child as a particle. (What's the moment of inertia of particle at a distance from an axis?) Just add the child's moment of inertia to that of the merry-go-round.
Yes.
So the moment of inertia for a particle is Mi*ri = (23)(1.2)=27.6
So I of the system is (230+27.6)=257.6. So now we take conservation of angular momentum:
L initial = L Final
L Initial = I*angular speed = 230*1.05 (10 rev/min = 20pi/min = 1.05rad/s?)
L Final = 257.6*angular speed, so we set this equal to each other
230*1.05 = 257.6w
w=.9375?
No. Does this expression even have the right units for moment of inertia?
whoops, r should be squared right...so (23)(1.2^2) = 33.12
So 230(1.05)=263.12w
w=,874?
Right sorry I always forget..it says I am off by a power of 10, why is this
Right. But be sure to include proper units when stating a physical quantity.
w=,874?
Check your arithmetic. Also, why not express the new angular speed in the same units as the original?
oh wow whoops so w=.917 so converting back we take (.17 * 60)/2*pi giving 8.75 rev/min. Thanks for the help
FAQ: Merry-go-round angular momentum conservation?
1. What is angular momentum conservation?
Angular momentum conservation is a fundamental principle in physics that states that the total angular momentum of a system remains constant in the absence of external torques. This means that the rotational motion of a system will not change unless acted upon by an external force.
2. How does angular momentum conservation apply to merry-go-rounds?
In the case of a merry-go-round, the angular momentum is conserved because the rotation of the system is not affected by any external forces as long as there is no friction or air resistance. This is why the merry-go-round can continue spinning at a constant rate even when people get on and off.
3. Why is angular momentum conservation important?
Angular momentum conservation is important because it allows us to predict the behavior of rotating systems. By understanding the principle of conservation, we can make accurate calculations and predictions about the motion of objects on a rotating platform, such as a merry-go-round.
4. Can angular momentum be changed on a merry-go-round?
Yes, angular momentum can be changed on a merry-go-round if an external force is applied. For example, if someone pushes or pulls on the merry-go-round, it will cause a change in the angular momentum of the system.
5. How does the distribution of mass affect angular momentum on a merry-go-round?
The distribution of mass on a merry-go-round affects the angular momentum of the system. This is because objects with more mass located at a greater distance from the center of rotation will have a greater angular momentum. This is why some people may feel a greater force when sitting on the outer edge of a spinning merry-go-round compared to those sitting closer to the center.
