Mesh Current Analysis for a Series-Parallel Circuit
The discussion focuses on mesh current analysis for a series-parallel circuit, emphasizing the correct application of Kirchhoff's Voltage Law (KVL) and the importance of sign conventions in setting up equations. The original poster struggles with incorrect current values for I1, I2, and I3, which deviate from instructor-provided answers. Key advice includes ensuring the correct direction of current flow across resistors and accurately calculating voltage drops based on these directions. The poster's initial equations for mesh analysis are identified as incorrect, particularly regarding the voltage drops across specific resistors. Properly applying these principles is essential for achieving accurate results in mesh current analysis.
gomezfx
Not necessarily any equations ,just systematic approaches for mesh current analysis like using KVL
Also used cramer's rule
My work:
http://i28.photobucket.com/albums/c216/aldodesigns/page1.jpg
http://s28.photobucket.com/albums/c216/aldodesigns/?action=view&current=page2.jpg
I found I1, I2, and I3 (I think) but they're not right. The answers my instructor gave us were 8A for the 110V source and 10A for the 12V source and I am way off. Did I set up my equations wrong?
Take care of your signs. Across a resistor, the current direction is always from the more positive terminal to the more negative one. If you decided the direction of current than you have the voltage drop always in that direction. You do not have the freedom to choose which terminal of a resistor is more positive than the other one, and you do not know it before you solve the problem for the currents.
So your first equations for mesh 1 and 3 are wrong.
In case of mesh 1 you have the current I1 - I2 flowing through the 12 ohm resistor. Going clockwise, the voltage drop is 12(I1-I2). In mesh 3, I3 current flows through the 4 ohm resistor, causing 4 (I3) voltage drop.
ehild
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
