How Do Reaction Forces Work at a Pin Joint in Truss Analysis?
The discussion focuses on understanding reaction forces at a pin joint in truss analysis, specifically at joint A. A pin joint can support both horizontal and vertical components of force, which are external to the truss members. At joint A, the reaction forces include an unknown horizontal component (Ax) and a vertical component (Ay). In contrast, the roller at joint D only supports a horizontal force. To determine these unknowns, users are advised to apply the three equilibrium equations of statics before using the method of joints to analyze member forces.
alex_the_seal
Hi there!
Can anyone take me through the method of joints procedure for this truss? I am having trouble working out the reaction forces at the pin at joint A. Is there supposed to be a vertical component to the reaction force as well a a horizontal (seeing as it is a pin)? And if so where does it go? is it part of the member AD or outside of it? I am confused.
P.S. The answers are AB = 5 kN T, BC = 5*sqrt(2) kN C, CD = 15 kN C, AC = 5*sqrt(2) kN T, AD = 0. Where T = tension, C = compression.
alex_the_seal said:
Hi there!
Yes. A pin can support both a horizontal and vertical component of force. The roller at D, on the other hand, can only support a force normal to its surface; in this case, the roller at D can support a horizontal force only.
All and any support reactions are external to the system; they are outside of the members. So at A, you have an unknown support reaction of Ax in the horizontal direction, and Ay in the vertical direction. At D, you have an unknown support reaction Dx in the horizontal direction. Use the 3 equilibrium equations of statics to solve for these unknowns. Then proceed with the method of joints to get the member forces. But first, what are the reactions?
