Microcantilever-direction of deflection
  • Thread starter Thread starter engineer23
    Deflection
A microcantilever-based hydrogen sensor utilizes a Palladium coating to absorb hydrogen, causing deflection that alters capacitance and indicates hydrogen concentration. The expected downward deflection contradicts the positive values reported in the study, leading to confusion about the measurement method, which may be based on deflection from the initial position. Additionally, the observed decrease in deflection with increasing hydrogen concentration raises questions about the relationship between hydrogen absorption and cantilever bending. The uncoated beam shows a negative deflection, further complicating the interpretation of results. Clarification on these points is necessary to fully understand the sensor's behavior and measurement approach.
engineer23
Microcantilever---direction of deflection
I was reading a paper on a microcantilever-based hydrogen sensor. Here's how the sensor works (as I understand it):
The cantilever is coated with Palladium film. In the presence of Palladium, diatomic hydrogen splits into H atoms, which are absorbed by the cantilever. The stress imposed by this absorbance bends the canitlever, which changes the capacitance. Thus, percent hydrogen is a function of capacitance.
I would expect the deflection to be downward. However, the plots in the article show that the values for cantilever deflection (as measured by an optical sensor) are positive. For example, for 10% H2 concentration, the measured deflection is ~.4 micrometers.
For 0.4% H2 concentration, the deflection is 1.2 micrometers.
Can someone explain this behavior? The diagram in the article that shows how the device works has the cantilever bending downward (which I assume would be a negative value of deflection), but the plots show positive deflection values.
Thanks for any help!
Are they just using the absolute value for the deflection?
Since you presumably can't have less than zero hydrogen it's only going to bend one way and it might just be easier for them to quote deflection from the initial position rather than an absolute Z value
I think you may be right. The diagram definitely indicates deflection is downard, so I think the values they report are deflection from initial position (absolute).
The only other thing that bothers me is that deflection appears to decrease with increasing hydrogen concentration. This doesn't make sense to me...it seems that the more H2, the more absorbed H, and the greater the deflection. Also, the uncoated (and thus unloaded) beam is reported to have a negative deflection.
The paper is by D.R. Basalt and appears in Sensors and Actuators B, vol. 88 (2003) pp. 120-131.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
