Microphone - transistor switching on a led
  • Thread starter Thread starter asa!!
    Led Transistor
To use a microphone to switch a transistor for lighting an LED, it's essential to select a microphone that can produce sufficient voltage to activate the transistor. A common choice is an electret microphone, which typically outputs around 0.5 to 1 volt. The transistor should be a low-saturation type, such as a BC547, suitable for low-voltage applications. The circuit will operate at a fixed supply voltage of 3.8V, which is compatible with the components discussed. Proper configuration will ensure that sound detected by the microphone effectively turns on the transistor and lights the LED.
asa!!
hi i want to use a microphone connected to the base of a transistor.yhe transistor should work as a switch . it should turn on with a sound to the micro phone. does anyone know what voltage the mic can produce?what kind of microphone do i need and what kind of transistor?the circuit is designed to light up a led. The voltage supply of the circuit, probably fixed to the collector of the cicrcuit is 3,8v.thank you
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
