Min torque rating for a gear and pinion
The discussion centers on the torque rating requirements for a pinion and gear system, specifically a pinion exposed to 100 oz-in and a gear exposed to 300 oz-in, with a gear ratio of 3. It is established that the pinion must have a torque rating above 100 oz-in to avoid failure, as each component's maximum load rating must not be exceeded. Additionally, incorporating a factor of safety (FOS) of 1.5 to 2 is recommended to account for potential overloading, ensuring the design remains robust under varying conditions.
  • Understanding of gear ratios and their impact on torque distribution
  • Knowledge of torque ratings and maximum load ratings for mechanical components
  • Familiarity with factors of safety (FOS) in engineering design
  • Basic principles of mechanical design and failure analysis
  • Research the calculation methods for gear ratios and their effects on torque
  • Explore the principles of selecting appropriate torque ratings for mechanical components
  • Learn about the application of factors of safety in mechanical engineering
  • Investigate common failure modes in gear and pinion systems
Mechanical engineers, design engineers, and anyone involved in the design and analysis of gear systems will benefit from this discussion.
{taylor}
I have a pinion exposed to 100 oz-in torque and a gear exposed to 300 oz-in of torque (gear ratio of 3).
Does the pinion need to have a torque rating above 100 or 300 oz-in?
Each component has a maximum load rating -- make sure the load on each separate component does not exceed the rating and your design should not fail. You may also want to add a factor of safety to account for possible overloading.
So theoretically, will the pinion break if sized for a torque rating of 100 oz-in? (I'd probably use a FOS of 1.5 or 2 though)
  • · Replies 24 ·
  • · Replies 23 ·
