Miniature sub pressure physics
In summary, The net force that must be withstood by the 1.5 m diameter hatch is the difference between the pressure inside the miniature sub (maintained at 1.0 atm) and the pressure outside in sea water at a depth of 8.5 m. This can be calculated using the formula for pressure, taking into account the density of water, gravity, and the height of the water column. However, you must also account for the area of the hatch in order to calculate the net force.
kiwikahuna
61
A miniature sub is lowered to a depth of 8.5 m in sea water of density 1.03 grams/cc. The interior of the research craft is maintained at 1.0 atm. Find the net force that must be withstood by a 1.5 m diameter hatch which leads to the inside.
Pressure = density * gravity * height
Pressure = P (atmospheric) + density * gravity * height
Mass = density * area* height
Pressure = 101300 + 1030 kg/m^3 (9.81m/s^2) * 8.5m
Once I found the pressure, I multipied it by the area (pi r^2)
The answer I got was wrong and I'm wondering what I did wrong. Please help.
You must consider the pressure on BOTH sides of the hatch.
There are a few things to consider in this problem. First, the density of sea water is given in grams/cc, so it needs to be converted to kg/m^3. This can be done by dividing by 1000, since 1 cc = 1/1000 m^3. So the density should be 1030 kg/m^3, not 1.03 kg/m^3 as given in the problem.
Next, the pressure at a depth of 8.5 m would be the sum of the atmospheric pressure (1 atm = 101300 Pa) and the pressure due to the depth of the water. So the correct equation to use would be:
P = 101300 Pa + 1030 kg/m^3 * 9.81 m/s^2 * 8.5 m
Once you have the pressure, you can calculate the force using the formula F = PA, where P is the pressure and A is the area of the hatch (pi*r^2). This should give you the correct answer for the net force that must be withstood by the hatch. Keep in mind that the pressure inside the sub will also contribute to the net force, but it is not specified in the problem and therefore cannot be calculated.
What is miniature sub pressure physics?
Miniature sub pressure physics is a branch of physics that focuses on the study of pressure in small-scale underwater environments, such as those found in miniature submarines.
How does pressure affect miniature submarines?
Pressure affects miniature submarines in the same way it affects larger submarines. As the depth increases, the pressure also increases, which can impact the structural integrity and functionality of the submarine.
What are the applications of miniature sub pressure physics?
Miniature sub pressure physics has various applications, including the design and development of miniature submarines for scientific research and military operations, as well as the study of pressure in small-scale underwater environments for understanding marine life and ecosystems.
What factors affect pressure in miniature submarines?
The main factors that affect pressure in miniature submarines are depth, volume, and density of the surrounding water. Other factors, such as temperature and salinity, may also play a role depending on the specific environment.
What are some challenges in studying miniature sub pressure physics?
One of the main challenges in studying miniature sub pressure physics is the limited availability of equipment and resources for conducting experiments in small-scale underwater environments. Additionally, the complex interactions between pressure and other factors, such as temperature and salinity, can make it difficult to accurately measure and predict pressure changes in these environments.
