What Is the Minimum Horsepower Required to Prevent a Ship from Sinking?
To prevent a leaking ship from sinking, a motor must pump 12.0 units of water per second up 1.50 meters. The initial calculation for work done was correct, yielding 176.4 watts. However, the solution should focus on power, using the formula P = W/t, which accounts for time. The mass of the water must be specified in kilograms for accurate calculations. Clarifying the units of water is essential to ensure the horsepower requirement is correctly determined.
pierra
In order to keep a leaking ship from sinking, it is necessary to pump 12.0 of water each second from below deck up a height of 1.50 and over the side.
What is the minimum horsepower motor that can be used to save the ship?
W=F*d
1 horse power = 746w
W=F*d
= mg*d
= (12*9.8)(1.50m)=176.4
176.4w(work) / 746w(horsepower) =0.23646..
p=0.236 hp
I can't see what did I do wrong. help me!
pierra, it looks like you found the Work rather than the power - better to start with a P = formula.
P = W/t = F*d/t would be a terrific start.
Convert the answer to horsepower.
You don't say what units the "12.0 of water" is in and I wonder if that is the trouble with the answer (if it is wrong). You'll need the amount of water in kg to put in for the mass.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
