Minimum Tension for Suspended 100kg Sign - Tension and Wires
  • Thread starter Thread starter russellmejia
    Tension Wires
To determine the minimum tension required for the wires supporting a 100 kg sign, one can use vector analysis or resolve the forces into their x and y components. The angle between the wires is 110 degrees, which affects the tension calculations. Participants in the discussion encourage sharing initial attempts and specific areas of confusion to facilitate targeted assistance. Engaging with the community can enhance understanding of the problem-solving process for this physics scenario.
russellmejia
A sign (m=100kg) is suspended by two wires as shown. Determine the minimum tension the wires mus be able to provide
110 DEGREES
100 kg
Diagram:
\110 /
________
| 100kg |
welcome to pf!
hi russellmejia! welcome to pf! :wink:
either use a vector triangle or use x and y components (separately) …
show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
