What is the stopping potential for a wavelength of 230nm?
In summary, to find the stopping potential for a wavelength of 230nm, you can use the equations Kmax = hc/lambda - workfunction and Kmax = eVs, where Kmax is the maximum kinetic energy, lambda is the wavelength, and Vs is the stopping potential. The workfunction only needs to be calculated once for a specific material.
Wardlaw
27
Modern Physics question!
When radiation of wavelength 350nm is incident on a surface, the maximum kinetic energy of the photoelectrons is 1.2ev. What is the stopping potential for a wavelength of 230nm?
[tex]\phi[/tex]=hc/[tex]\lambda[/tex]-eV0( V0= V 'nought')
I am unsure as to what other equations can be used.
My attempt was to calculate [tex]\phi[/tex] for the 350nm wavelength, and then do the same for the 230nm wavelength.
in this problem you can make use of two equations:
(1) : Kmax = hc/lamda - workfunction (Kmax is the max. kinetic energy , lamda is the wavelength)
(2) : Kmax = eVs (Vs is the stopping potential)
your start is good .. when you get the work function for the 350 nm wavelength , use that workfunction again with equation (1) along with the 230 nm wavelength to get Kmax and then use equation (2) to get the stopping potential ..
note : you just need to calculate the workfunction just once since that value is fixed for a certain material .. :)
1. What is modern physics?
Modern physics is a branch of physics that deals with the study of the fundamental particles and forces that make up the universe, as well as the behavior of matter and energy on a very small scale. It includes theories such as quantum mechanics, relativity, and nuclear physics.
2. What is the difference between classical physics and modern physics?
Classical physics is the branch of physics that studies the behavior of matter and energy at a macroscopic level, while modern physics focuses on the behavior of matter and energy at a microscopic level. Classical physics is based on Newton's laws of motion, while modern physics is based on quantum mechanics and relativity.
3. What are the major theories in modern physics?
The major theories in modern physics include quantum mechanics, which explains the behavior of particles on a subatomic level, and relativity, which explains the behavior of objects at high speeds or in strong gravitational fields. Other important theories include nuclear physics, which studies the structure and behavior of atomic nuclei, and particle physics, which studies the fundamental particles and forces of the universe.
4. How has modern physics changed our understanding of the universe?
Modern physics has revolutionized our understanding of the universe by providing a more accurate and comprehensive explanation of the behavior of matter and energy. It has helped us understand the fundamental building blocks of the universe, such as particles and forces, and has also led to advancements in technology, such as nuclear power and quantum computing.
5. What are some real-world applications of modern physics?
Modern physics has numerous real-world applications, from medical imaging technologies such as MRI and PET scans, to GPS systems and nuclear energy. It also plays a crucial role in the development of new materials and technologies, such as superconductors and semiconductors, which are used in electronics and telecommunications.
