Modified heat equation steady state
4 replies · 4K views
dp182
determine the steady state equation for the given heat equation and boundary conditions
Ut=Uxx-4(U-T)
U(0,T)=T U(4,T)=0 U(x,0)=f(x)
I put Ut=0
so 0=UInf''-4(Uinf-T)
then once I tried to integrate I ended up with a Uinf that's impossible to isolate is there a specific method used for this kind of heat equation?
The steady state is usually when the system is time independent, so:
[tex] \frac{\partial U}{\partial t}=0[/tex]
So this will turn your equation into and ODE, which I see you have already done and your ODE is:
[tex] \frac{\partial^{2}U}{\partial x^{2}}-4U+4T=0[/tex]
I am not too sure what T is, is it a constant? A function?
Ut=Uxx-4(U-T)
I put Ut=0
What do you mean by "impossible to isolate". Calling what you call Uinf u(x) for simplicity the equation you have written is just
u''(x) - 4u(x) = -4T
u(0) = u(T) = 0
A second order constant coefficient ODE.
I believe T is constant. so I tried using variation of parameters to solve (Uinf=X) X''-4X=-4T
and came up with a particular solution of
c1e2x+c2e-2x-T then solved for the constants using boundary conditions. is this method right as all the example I have seen involve just integrating it twice.
That should work, but I'm guessing it gets a bit messy solving for the constants. Here's a little trick you might like to learn. You probably know that instead of using the pair {e2x,e-2x} for the general solution of the homogeneous equation, you could have used {sinh(2x),cosh(2x)}, which simplifies things a bit when you calculate X(0) = 0. But an even better choice is the pair {sinh(x),sinh(T-x}. Try evaluating the constants when you write your solution
X(x) = Asinh(x)+Bsinh(T-x) + T
and you will see what I mean.
