How Do You Calculate the Molar Mass of an Unknown Gas?
  • Thread starter Thread starter chem
    Gas Mass
To calculate the molar mass of an unknown gas using a sample of hydrogen, first determine the volume of hydrogen gas at given temperature and pressure using the ideal gas law. This volume can then be applied to find the density of the unknown gas under the same conditions. By calculating the number of moles of the unknown gas based on its volume, the molar mass can be derived. The process assumes that both gases behave ideally. This method effectively allows for the determination of the unknown gas's molar mass.
chem
1. A sample bulb contained 0.712 g H2 (g) at a certain temperature and pressure. Under the same conditions of temperature and pressure, the bulb can hold 13.0 g of an unknown gas. What is the molar mass of the unknown gas?
Obtaining H2 volume from the ideal gas law (assuming STP) and then using that volume to obtain the unknown gas density (with STP) is the correct way to obtain the molar mass?
I would appreciate some help
Thank you.
Assume the gas follows the ideal gas law. For the hydrogen example you know the pressure/temperature and the number of moles. From that you can calculate the volume of the vessel. Use this solution (same pressure, temperature and volume) to determine the number of moles of the unknown gas. From that you can calculate the molecular weight of the unknown gas.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
