Molarity given percent solution and density.
To calculate the molarity, molality, and mole fraction of a 12.0% lactose solution with a density of 1.06 g/mL, one must first determine the mass of lactose in a given volume of solution. The initial attempt at calculating molarity was incorrect due to unit conversion errors. The correct approach involves converting the percentage concentration to moles using the molecular weight of lactose and the solution's density. It's essential to track units throughout the calculations to ensure accuracy. Properly following these steps will yield the desired concentrations.
webz
Lactose (C12H22O11; MM=342) is a sugar found in mamalian milk. The density of a 12.0% solution is approximately 1.06 g/mL. What is the molarity, molality, and mole fraction of the solution?
M=g/L, m=mol/kg, molefraction=mol/mol??
I think I can get this one if I can just determine the molarity. I definitely did something wrong.
M=mol/L
1.06 / 1000 = .00106; .00106/342 = 3.099x10^-6M
I figured since I know g/mL as well as mol/g, I can divide to get mol/mL, then convert to get L. Apparently this is not the case?
You're on the right track, just a few things you need to pay attention to:
1.06 grams of solution contains how many grams of lactose?
Also, show your units at all steps of the calculation to make sure you're converting correctly.
Hmm, then let me try this again. I just want to find the moles of Lactose for now, then I think I got the rest.
1.06 g/mL * 1mol/342g * 12% lactose = 3.719x10^-4
Does that look right?
Thanks for the help btw.
That looks good, but remember to keep track of the units.
Moles of lactose in what?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
