Moment of inertia rigid body problem
The discussion focuses on calculating the moment of inertia (MoI) for a rigid body shaped like an "H," composed of three identical thin rods. Participants explore the application of the parallel axis theorem to determine the MoI of each rod relative to the rotation axis. The correct MoI is established as 4/3mL^2, accounting for the contributions from the two vertical rods and the horizontal rod. The conversation highlights the importance of understanding the specific conditions under which different MoI formulas apply. Ultimately, the participant successfully calculates the angular speed of the body when it falls to a vertical position.
i_hate_math
A rigid body is made of three identical thin rods, each with length L = 0.530 m, fastened together in the form of a letter H, as suggested by the figure here. The body is free to rotate about a horizontal axis that runs along the length of one of the legs of the H. The body is allowed to fall from rest from a position in which the plane of the H is horizontal. What is the angular speed of the body when the plane of the H is vertical?
This is really a conservation of energy question but the hard bit is to find out the moment of inertia of this object.
K+P=K+P
K=0.5I*w^2
==> 2mgL=(1/2)I*w^2 +(1/2)mgL
and from this equation w can be easily found. However, i canot seem to get the correct Rotational Inertia. Can anyone show me how to find the moment of inertia for this system??
What have you tried? What equations are relevant for dealing with the moment of inertia of thin rods?
Which rods contribute to the MoI about that axis? Find the MoI of each.
That is where i got stuck. For some reason i believe the Moment of inertia for this system is 1/3mL^2+mL^2, but it doesn't lead to the correct answer
I know that only the two rods on the RHS of the 'H' contribute to the moment of inertia. But I have no clue how to find the MoI. Is it the parallel axis theorem?
The parallel axis theorem is involved for one of the rods (which one?).
What is the MoI of a thin rod about its center of mass?
Depending on your starting formulae, the parallel axis theorem may apply to both rods.
True, but I've found that the formula most often given for a thin rod is the one for it rotating about a line perpendicular to the rod and passing though its center of mass.
That would be the y-axis or z-axis in the figure.
The one parallel to rotation axis i suppose?
gneill meant the other one (see post #8), but arguably it can be used for both.
I know the outer rod has I=(1/3)mL^2 +mL^2, but how do i find the inner perpendicular rod's?
Ah, the dangers of quoting formulae without understanding when they apply.
The 1/3 formula you quote is for a rod of what length rotating about what axis?
TBH i have no idea. Only these cases are included in the textbook and i got that one from the internet. So I=1/2mL^2 ?
so after a quick research, 1/3mL^2 is rotation about an axis thru one end of the rod and 1/2mL^2 + mL^2 is the MoI for the parallel rod(by parallel axis theorem). Does that look right?
None in that image show a factor 1/3, so where did that come from?
An axis perpendicular to the rod and through one end, yes.
No. Where did the 1/2 term come from?
thats the MoI of the rod thru a parallel axis(ie Icom) and I=0.5mL^2+mL^2 by parallel axis theorem
The "i.e." is not appropriate. The direction of the axis and the point it passes through are independent.
To apply the parallel axis theorem you first need to identify an axis parallel to the given axis and passing through the mass centre of the body.
What does that parallel axis look like in this case, from the viewpoint of the rod?
Is the axis pointing thru the rod? Thats parallel tocthe original axis
Along the rod, yes. What do you think its moment of inertia would be about such an axis? (You won't find this one in any table, it's too simple!)
Simply m*L^2?
i_hate_math said:
Simply m*L^2?
No, it's even simpler.
Start with a point particle, mass m. What is its moment of inertia about a point distance L away? Based on that, what is its moment of inertia about its own position?
for one particle, MoI is mL^2, and for all the particles on this rod, the sum of all mL^2 would be ML^2 where M is the mass of the rod? and for the rod at the original axis, sinece its a "thin" rod, L can be ignored i guess
Yes, but you need to answer my next question too:
(What is L then?)
(What is L then?)
L is the length of the rod?
I asked about the moment of inertia of a point particle, not a rod, about a point at distance L from it. You correctly answered mL2. Now I am asking you about a special case of this: when the point particle is at the axis point. What is the value of L in that case? What moment of inertia do you get?
Then it would be the radius of the rod, and in this case, as the question has indicated, a "thin" rod has negligible radius and hence L=0
Right, so what is the moment of inertia?
0 for this rod, and the total would be 1/3mL^2 by itself?
Oops no, 1/3mL^2 +0+mL^2 by the parallel axis theorem
  • #31
We are not quite ready to go back to considering the rod. I am still asking about the point particle.
Edit: cancel that, see below.
  • #32
i_hate_math said:
0 for this rod
Yes, the moment of inertia of a thin rod about itself as axis is 0.
Now use the parallel axis theorem to find its moment of inertia about the rod parallel to it in the H figure.
  • #33
The parallel axis thrm states that I=Icom+mh^2
here it's I=0+mL^2=mL^2
  • #34
Yes!
Do you see why this is? Every point of the rod is at distance L from the axis, so each little mass dm contributes L2.dm to the total.
  • #35
haruspex said:
Yes!
Yeah because its a rigid body of many particles. And adding them up, I-total=1/3mL^2+0+mL^2=4/3mL^2
  • #36
In post #33 you came to understand that the moment of inertia of a rod about an axis parallel to it, distance L away, is mL2. Why have you gone back to 1/3mL^2+mL^2?
  • #37
because I think the other rod that's perpendicular to the rotation axis also needs to be taken into account for the total MoI
  • #38
Oh, ok, I didn't realize you were including that yet. In that case, yes, that is indeed the total MoI of the H shape about the given axis.
  • #39
Thanks a lot mate for all the help and detailed explanations. I got the correct answer 6.45 eventually!
