Moment of Inertia using Triple Integral
The moment of inertia around the z-axis for a solid unit box defined by [0,1]x[0,1]x[0,1] with a density function of \(\delta = x^{2} + y^{2} + z^{2}\) can be computed using the triple integral \(I = \int\int\int r^{2} \delta dV\). The distance \(r^{2}\) from the z-axis is represented as \(x^{2} + y^{2}\). The integration bounds for each variable are from 0 to 1, leading to the integral setup: \(\int_{0}^{1}\int_{0}^{1}\int_{0}^{1}(x^{2}+y^{2})(x^{2}+y^{2}+z^{2})dzdydx\). The order of integration does not affect the outcome due to the independence of the volume boundaries.
  • Understanding of triple integrals in multivariable calculus
  • Familiarity with the concept of moment of inertia
  • Knowledge of density functions in physics
  • Basic skills in evaluating integrals
  • Study the properties of moment of inertia in three-dimensional bodies
  • Learn about the application of triple integrals in calculating volumes and mass
  • Explore the use of density functions in physics and engineering
  • Practice setting up and evaluating multiple integrals with varying bounds
Students in physics and engineering courses, particularly those studying mechanics and multivariable calculus, as well as educators looking for examples of applying triple integrals to real-world problems.
jj2443
Compute the moment of inertia around the z-axis of the solid unit box [0,1]x[0,1]x[0,1] with density given by [itex]\delta[/itex]=x[itex]^{2}[/itex]+y[itex]^{2}[/itex]+z[itex]^{2}[/itex].
I=[itex]\int[/itex][itex]\int[/itex][itex]\int[/itex]r[itex]^{2}[/itex] [itex]\delta[/itex] dV
I know that the distance r[itex]^{2}[/itex] from the z-axis would be x[itex]^{2}[/itex]+y[itex]^{2}[/itex]. I don't know how to determine the bounds and the order of the three integrals. Could someone please explain to me how to determine which order I should integrate, and then how I go about finding the bounds of integration for each of the three integrals.
Thanks!
Since none of the boundaries on your volume is dependent on each other you can just write it as a simple 'volume' integral if you want to think of it that way, as if you're finding the volume of the cube but with the other terms involved: [itex]r^{2}[/itex] and [itex]{\delta}[/itex]
So in my mind it should be set up as follows:
[tex]\int_{0}^{1}\int_{0}^{1}\int_{0}^{1}(x^{2}+y^{2})(x^{2}+y^{2}+z^{2})dzdydx[/tex]
The order of integration won't matter.
Oh, that's much easier than I was trying to make it. Thank you!
