Moment of Inertia: Find 0.25-kg 4-Point Mass Square Rigid Body
The discussion focuses on calculating the moment of inertia for a square rigid body composed of four 0.25-kg point masses. The user initially provided incorrect values for the moments of inertia about various axes, specifically for parts a, b, and c. After receiving guidance on using the formula I = Σ m_i r_i^2, they recalculated and successfully found the correct values for all parts, including part d. The key takeaway emphasizes the importance of correctly determining the distances from the masses to the axes of rotation. Accurate geometric considerations are essential for solving moment of inertia problems effectively.
endeavor
Four 0.25-kg point masses connected by rods of negligible mass form a square rigid body with 0.10-m sides Find the moment of inertia of the body about each of the follwoing axes: (a) an axis perpendicular to the plane of the squuare and through its center, (b) an axis perpendicular to the plane and through one of hte masses, (c) an axis in the plane and along one side through two of the masses, and (d) an axis in the plane running diagonally through two fo the masses.
my answers are a. 1.7 * 10^-3, b. 2.2 * 10^-2, c. 3.3 * 10^-3, and I don't know how to solve d. However, when I checked my answers in the back of my textbook, a. is 5.0 * 10^-3, b. 1.0 * 10^-2, c. 5.0 * 10^-3.
What am I doing wrong...?
Remember that you can get the moment of inertia through
I=\sum m_{i}r_{i}^2
where r is the distance from the mass to the axis. So in part a, the distances from the masses to the axis are equal and by simple geometry 0.1/\sqrt{2}. The rest should be done in a similar way.
okay, i got a,b, c, and d. thanks
