Moment of Inertia of Rod About Axis XX': ML2/3sin2α
The moment of inertia of a rod about an axis XX' through its center of mass at an angle α is given by the formula ML²/3sin²α. The discussion highlights confusion regarding the appearance of the sin² term in the equation. It emphasizes that the distance along the axis does not influence moments about the axis; instead, the relevant distance is from the XX' axis to points on the rod. A suggestion is made to set up an integral to better understand the calculation. Understanding these concepts is crucial for accurately determining the moment of inertia in this scenario.
Aditya1998
1. The problem statementα, all variables and given/known data
The moment of inertia of a Rod over an
Axis XX' passing through the center of mass of the Rod at an angle α is-
Moment of Inertia of Rod about the end, I =ML2/3
I=ML2/3
Answer of the question is ML2/3sin2α
I didn't understood how sin2 came because even if we shift OL over the axis XX' then
OX=OLcosα
[/B]
Hint: Set up an integral.
OX=OLcosα
The distance along the axis, OX, does not affect moments about the axis. The distance of interest is from the XX' axis to the points on the rod.
