Calculating Moment of Inertia for a Thin Spherical Shell
  • Thread starter Thread starter tak08810
    Moment
The problem involves calculating the moment of inertia for a rubber ball modeled as a thin spherical shell, with a mass of 60.0 g and a diameter of 6.98 cm. The correct formula for a thin spherical shell is I = 2/3 Mr^2, not the one initially used. Despite multiple attempts, the user struggled with incorrect submissions and unit conversions. Ultimately, they found the correct answer from another source, indicating a resolution to their confusion. The discussion highlights common pitfalls in physics calculations, particularly in applying the correct formulas and unit conversions.
tak08810
Ok this problem is really really ticking me off because it seems so damn simple.
"A rubber ball has a mass of 60.0 g and a diameter of 6.98 cm. Find the moment of inertia about its diameter. Model the ball as a thin spherical shell."
Ok so moment of interia for a sphere shaped object is 2/5Mr^2 correct? So I convert grams to kg, cm to meters, plug the numbers in (radius = 0.0349 m) and get 2.92 *10^-5 kg*m^2. But this is wrong? I don't understand what I'm doing wrong. I assume I'm looking at this problem in completely the wrong way. Here is the list of attempts I've put in:
Submission # Try Submitted Answer
1 Incorrect. (Try 1) 2.92 *10^-5 kg*m^2
2 Incorrect. (Try 2) 1.17 *10^-4 kg*m^2
3 Incorrect. (Try 3) 7.30 *10^-5 kg*m^2
4 Incorrect. (Try 4) 2.92 *10^-4 kg*m^2
5 Incorrect. (Try 5) 2.93 *10^-5 kg*m^2
6 Incorrect. (Try 6) 2.91 *10^-5 kg*m^2
7 Submission not graded. Use more digits. 2.9 *10^-5 kg*m^2
8 Submission not graded. Use fewer digits. 1.1692896 *10^-4 kg*m^2
9 Incorrect. (Try 7) 1.1692 *10^-4 kg*m^2
10 Incorrect. (Try 8) 0.000 kg*m^2
11 Incorrect. (Try 9) 0.000292 kg*m^2
12 Incorrect. (Try 10) 0.000117 kg*m^2
13 Incorrect. (Try 11) 0.0004188 kg*m^2
14 Incorrect. (Try 12) 0.004188 kg*m^2
15 Incorrect. (Try 13) 0.000251 kg*m^2
16 Incorrect. (Try 14) 0.000251 g*m^2
17 Incorrect. (Try 15) 2.92 *10^-5 kg*m^2
NVM I got the answer from another site. Thanks anyways!
