Momentum and Energy: Find Maximum Energy Stored in Bumper
The discussion focuses on calculating the maximum energy stored in the bumpers of two colliding blocks, where block a (mass 3.50 kg) moves at 2.00 m/s towards block b (mass 10.00 kg) at rest. The conservation of energy principle is applied, with the initial kinetic energy of block a calculated as 7 J. To find the velocities of both blocks post-collision, participants suggest setting up two equations: one for momentum conservation and another for kinetic energy conservation, leading to two unknowns that need to be solved simultaneously.
  • Understanding of conservation of momentum
  • Knowledge of kinetic and potential energy concepts
  • Ability to solve simultaneous equations
  • Familiarity with elastic collisions
  • Study the principles of conservation of momentum in collisions
  • Learn about elastic potential energy in spring systems
  • Practice solving simultaneous equations in physics problems
  • Explore the dynamics of elastic collisions in one-dimensional motion
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators seeking to enhance their teaching methods in collision dynamics.
zhuyilun
Blocks a (mass 3.50 kg ) and b(mass 10.00 kg ) move on a frictionless, horizontal surface. Initially, block b is at rest and block a is moving toward it at 2.00 m/s . The blocks are equipped with ideal spring bumpers. The collision is head-on, so all motion before and after the collision is along a straight line. Let positive x be the direction of the initial motion of a.
find maximum energy stored in the bumper and the velocity of a and b at that time
this question seems easy, but i just don't know how to start. can anyone give me a hint?
Conservation of energy is a good place to start. You know how much kinetic energy block a initially has. Therefore, you know how much energy is going to be stored in the springs as elastic potential energy.
initially a has 0.5*(2)^2*3.5=7 j energy. i tried, but this is not the correct answer
You need to set up two equations and two unknowns. In this case your momentum and KE both give you the same numeric value. Set up one equation for momentum after collision. Set up you second equation for the KE after collision. Then solve for the velocity of the smaller mass using the two equations and two unkown velocities. When you solve for the smaller mass velocity you will get two roots. One will be the initial velocity and is the situation when the second mass doesn't move. Use the other value to solve for the velocity of the heavier mass. Good Luck.
  • · Replies 25 ·
