Why is the Electron's Momentum Higher in Special Relativity?
The discussion centers on why an electron's momentum in special relativity is greater than that predicted by Newtonian mechanics. It is established that at high speeds, the electron behaves as if its mass is greater than its rest mass, leading to increased momentum. While statement A is identified as the correct answer, statement C is acknowledged as relevant since special relativity primarily applies at speeds close to the speed of light. Participants clarify that at lower speeds, the increase in mass is negligible. The consensus confirms that the increase in momentum is due to relativistic effects on mass.
JDiorio
Why is the value of the electron's momentum according to special relativity larger than that predicted by Newtonian mechanics?
A. At high speeds, the electron responds to forces and collisions as if its mass
were greater than the rest mass
B. At high speeds, the total momentum of two colliding particles is not conserved
C. Special relativity only applies at speeds close to the speed of light
p= m(Vo)/sqrt(1-beta^2)
I believe that the answer is A because as the velocity of an object approaches the speed of light, the momentum increases because its mass begins increase. So therefore at high speeds it would act as if its mass is greater than if it were at rest. Please let me know if this is the correct answer. Thank you
you're correct, at high speeds it's mass energy is greater than that of it's rest mass, so it's mass (and therefore momentum) increases, also seen by E = \frac{mc^2}{root(1-B^2)}
Well it is true but there is something that is not fully clear here;
Statement C is also right, if an object is not close to the speed of light the change in its mass can be neglectible,it is just so little.But it is still appliable.So i guess the answer is A but in my opinion statement C should be clearer anyway...
thanks a lot for everyone's help!
Glad it worked out. I solved this by process of elimination; without thinking much about it B and C are false statements.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
