P=Fv=1*42*vHomework: Calculating Momentum, Speed, and Power
The discussion focuses on calculating momentum, speed, and power for a block subjected to a time-varying force on both frictionless and rough surfaces. For part (a), the final momentum at t=5s is derived using the integral of the force function, yielding a result dependent on the constant Beta. In part (b), the speed of the block on a rough surface is calculated by considering the net force after accounting for friction, leading to a formula that incorporates the coefficient of static friction. Part (c) involves calculating power at t=4s, using the force and speed determined in previous parts. The responses confirm the approach is correct, emphasizing the need to substitute numerical values for final answers.
Tanero
A block of mass m=2 kg is initially at rest on a horizontal surface. At time t=0, we begin pushing on it with a horizontal force that varies with time as F(t)=Beta t^2, where Beta = 1.0 N/s^2. We stop pushing at time t1, 5s [F(t)=0 for t>1].
(a) First, assume the surface is frictionless. What is the magnitude of the final momentum at t1=5s?
P final(t=t1)=
(b) let's now consider a new situation where the object is initially at rest on a rough surface. The coefficient of static friction is 0.2. What is the speed of the block at time t2=5s?
v(t=t2)=
(c) What is the power P provided by the force F(t) at time t3=4s (in Watts) i the case where there is friction (part(b))?
P(t=t3)=
Can you please check if my approach is right? I have some doubts.
p=∫Fdt ,
instantaneous power P=Fv
part a) p=∫βt2=1/3βt3
part b) F - f_k = ma
F - f_k = mdv/dt
(F - f_k)dt = mdv
∫(F - f_k)dt = ∫mdv
mv_f - mv_i = (β/3)(t_f)^3 - (f_k)t_f - [(β/3)(t_i)^3 - (f_k)t_i] [v_i = 0 and t_i = 0]
mv_f = (β/3)(t_f)^3 - (f_k)t_f
part c)
P=Fv
to find v I used same approach as for b (but for t=4) and F=1*42
Your work looks good. You didn't include β in your expression for the answer in (a), but I guess that's because it has a numerical value of 1 N/s2.
Of course you will need to plug in the time values and figure out the friction force to get your final numerical answers.
Good work.
[Welcome to PF!]
