Exploding Pumpkin: Solving for Third Fragment's Velocity, Direction, and Mass
  • Thread starter Thread starter Forerunner546
    Homework Momentum
A pumpkin of mass 3.30 kg explodes into three pieces, with one piece weighing 0.50 kg moving north at 3.2 m/s and another weighing 1.4 kg moving southwest at 4.1 m/s. The conservation of momentum must be applied in both the x and y directions, acknowledging that the initial momentum is zero. The third piece's mass can be determined by subtracting the known masses from the total mass, while its velocity and direction can be found using vector equations and trigonometric laws. A force diagram is recommended to visualize the problem and clarify the angles involved. Properly applying these principles will lead to the correct solution for the third piece's speed, direction, and mass.
Forerunner546
A pumpkin of mass 3.30kg at rest on a smooth frictionless plane, explodes into 3 pieces in the horizontal plane. A .50kg piece flies to the North at 3.2m/s. A 1.4kg piece flies off (SW) at 4.1m/s.
What is the speed, direction and mass of the third piece?
M1V1o + M2V2o = M1V1f + M2V2f
I assumed the piece was 1.4kg as I subtracted the original pumpkins mass by the known fragmentary masses. I used the conservation of momentum to subtract the original pumpkins mass and velocity by the unknown fragment and equaled it to the two known pieces. M1V1o - M3V3f = M1V1f + M2V2f
This yielded -5.2 as a velocity which seems wrong, and I have no idea how to find the direction of the third piece and no angles were included.
The FIRST thing you should always do in working on such problems is to draw a force diagram. For unknown forces you estimate at direction and magnitude from the known forces/directions. Do that and present it here and then we can help you work on the problem.
They do give angles, just not in the sense you may be used to. Get a Compass Rose and find direction of North and South West, then figure out what angles these are.
Here’s a diagram
Can't tell where you are going wrong if you do not post your working.
Forerunner546 said:
Here’s a diagram
Hello @Forerunner546 . :welcome:
Your equations are vector equations, because momentum is a vector quantity. So is velocity.
What is the initial momentum ?
There is no initial momentum
Right. So write out the momentum conservation equations for two orthogonal directions.
By this I assume that you mean: the initial momentum is zero.
That's correct.
You can also solve this by arranging the momentum vectors in a triangle and using Law of Cosines and/or Law of Sines.
