Momentum & Kinetic Energy problem
The discussion revolves around a student's vehicle project, analyzing the concepts of impulse, work, momentum, and kinetic energy. The vehicle, with a mass of 5.70 kg, accelerates as a load descends, raising questions about the forces and energy transformations involved. It is confirmed that the floor imparts impulse to the vehicle, quantified as 13.11 kg*m/s, while it does not perform work due to the perpendicular force direction. The final momentum and kinetic energy of the vehicle derive from the potential energy of the elevated load. The forward acceleration is attributed to the axles' motion, with implications that the floor also plays a role in the vehicle's momentum.
potato1
For a technology project, a student has built a vehicle, of total mass 5.70 kg, that moves itself. As shown in the figure below, it runs on two light caterpillar tracks that pass around four light wheels. A reel is attached to one of the axles and a cord originally wound on the reel passes over a pulley attached to the vehicle to support an elevated load. After the vehicle is released from rest, the load descends slowly, unwinding the cord to turn the axle and make the vehicle move forward. Friction is negligible in the pulley and axle bearings. The caterpillar tread does not slip on the wheels or the floor. The reel has a conical shape so that the load descends at a constant low speed while the vehicle moves horizontally across the floor with constant acceleration, reaching final velocity of 2.30i m/s.
(a) Does the floor impart impulse to the vehicle? If so, how much?
(b) Does the floor do work on the vehicle? If so, how much?
(c) From where does the final momentum of the vehicle come?
(d) From where does the final kinetic energy of the vehicle come?
(e) Which force causes the forward acceleration of the vehicle?
F=ma
Impulse=change in momentum
(a) Yes, 13.11 kg*m/s
(b) No; the direction of the floor's force would be perpendicular to the direction of motion
(c) Not sure. I think it has to be something moving in the opposite direction of the vehicle since v0=0.
(d) The elevated weight since the potential energy is turned into kinetic energy
(e) The axles since they are turning, thereby causing forward accelerationThanks in advance to anyone who takes the time to read all that. Am I understanding all these concepts right or are my answers going awry? Also, any hints to (c)?
Your (a) answer shows you are thinking of Newton's 3rd law - a car accelerates by pushing back on the road and the road in return pushes forward on the car. Does the same thing apply to the rest of the answers?
Do you mean I should be applying that law to everything, or that my (a) answer is incorrect?
If you meant I should be applying that law, I can see how (e) would change to "from the floor." Would that make (c) from the floor as well? I don't think (b) or (d) would change (am I right?).
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
