Momentum of a Ball tossd in the air.
A ball thrown upwards with 10 units of momentum results in an equal and opposite momentum of 10 units for the Earth, demonstrating the conservation of momentum principle. The equation m1 x Δv1 = -m2 x Δv2 supports this concept, indicating that the Earth's recoil occurs in the opposite direction to the ball's motion. The conclusion drawn is that the statement about the Earth's recoil is true. The participant confirmed their understanding and received a correct grade on the assignment. This discussion emphasizes the importance of momentum conservation in physics.
Hannah1
A ball was thrown up from the ground with 10 units of momentum. The momentum of the recoil of the Earth is also 10 units of momentum. This means that the Earth recoils with a certain velocity in the opposite direction to the ball.
True or False?
Momentum Conservation Principle
I believe the answer is True because:
Am I correct?
yes :smile:
tiny-tim said:
yes :smile:
Thank you! I submitted the assignment, and it was the correct answer!
