Momentum of ball bouncing off crossbar
  • Thread starter Thread starter luffy3san
    Ball Momentum
A soccer ball with a mass of 416 g bounces off a crossbar at a 56.7° angle, with a kinetic energy of 46.9 J. The velocity of the ball after the deflection is calculated to be 15 m/s. The horizontal and vertical components of the momentum are found to be 3.43 kg m/s and 5.22 kg m/s, respectively. However, these values were marked incorrect, prompting a discussion about potential factors like angular momentum, which has not yet been covered in class. Clarification from the instructor is suggested to resolve the discrepancy.
luffy3san
A soccer ball with a mass of 416 g bounces off the crossbar of a goal and is deflected upward at an angle of 56.7° with respect to horizontal. Immediately after the deflection, the kinetic energy of the ball is 46.9 J. What are the vertical and horizontal components of the ball's momentum immediately after striking the crossbar? (Let the horizontal direction be the x-direction and the vertical direction be the y-direction.)
P = mv
KE = 1/2mv2
KEf = 0.5 * m * v2
46.9 = 0.5 * 0.416 * v2
v = 15 m/s
P = mv
Px = 0.416 kg * 15 m/s * cos 56.7 degrees = 3.43 kg m/s
Py = 0.416 kg * 15 m/s * sin 56.7 degrees = 5.22 kg m/s
Any help is appreciated. Thanks.
You should keep units everywhere, but I don't see where you need help.
Ah sorry... I got those two values for the momentum, they were one of the options but was marked as wrong.
I get the same answers as you - assuming the ball's not spinning.
Oh, thanks. We haven't covered angular momentum yet so shouldn't be... i think. I'll have to ask the instructor next class.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
