Momentum Problem - Is it correct?
  • Thread starter Thread starter AnomalyCoder
    Momentum
In a collision problem involving a 4kg cart moving at 14m/s and an 8kg stationary cart, momentum conservation principles are applied. The initial momentum of the 4kg cart is calculated as 56kgm/s, which becomes zero after the collision. The momentum transferred to the 8kg cart must equal this initial momentum, leading to the equation -56kgm/s = 8x, where x is the final velocity of the 8kg cart. The correct interpretation shows that the 8kg cart's velocity is half that of the 4kg cart, without the need for negative signs in the final momentum calculation. The discussion emphasizes that momentum is conserved in the system, confirming the relationship between the two carts' velocities post-collision.
AnomalyCoder
A 4kg traveling at 14m/s collides with a stationary 8kg cart. The collision causes the 4kg cart to completely stop, and sets the 8kg cart in motion. Determine the velocity of the 8kg cart after the collision.
m1 = -m2
VFinal-VInitial = m
Initially the velocity of the 4kg is 4kg*14m\s, or 56kgm/s.
After it halts completely, therefore a velocity of 0.
m1 = 0-56kgm\s.
Next the 8kg cart; initially it is at 0kg\s.
After it is 8kg*x.
(8x-0) = m2
Thus -56kgm\s = 8x;
x = -7kg/s.
m1 = -m2, therefore -7 becomes 7?
I'm not sure if this is correct. Any help, tips, and resources appreciated.
Your units are all over the place. But the general idea is correct. Momentum is conserved because there is no force acted on the system. Therefore, the momentum before the collision equals the momentum after the collision. Thus, since your original mass is 4 kg and it is traveling at 14 m/s, it's momentum is 14 * 4. This must be the same as the other object's momentum afterwards. Therefore, the magnitude of the second object's velocity is simply half of the first object's velocity.
Total momentum before collision = total momentum after collision. There is no negative sign.
He has used the same concept but written it as:
momentum lost by one body = momentum gained by the other.
since there is "gained" at one place and "lost" at the other there is a negative sign.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
