Calculating Momentum and Speed in a Collision
  • Thread starter Thread starter thomas49th
    Momentum
The discussion focuses on calculating momentum and speed in a collision involving two trolleys. The total momentum before the collision is determined using the formula momentum = mass x velocity, resulting in 6 kg·m/s. After the collision, since the trolleys stick together, their combined mass is used to find their speed, yielding 2 m/s. The solution confirms that the direction of speed is not required, as only the magnitude is needed, which is always expressed as a positive value. The calculations are validated, ensuring correct units and understanding of the principles of momentum conservation.
thomas49th
A trolley of mass 2kg, traveling at 3m/s, collides with a stationary 1kg trolley. If the trolleys stick together, calculate:
a) the total momentum before thecollision
b) the speed of the two trolleys arter th collision
momentum before collision or explosion = momentum after collision or explosion
a collision is where equal forces act in opposite directions. An explosion is when objects
how do i get B?
You get part b using the second equation.
Total momentum before collsion=total momentum after collision.
The fact that the cart sticks tells you what about their velocities after they collide?
if they collide and stick don't you add there masses to together so you have
2 x 3 = 2+1 x v
6 = 3 x v
6 / 3 = 2m/s
is that right?
is the answer the right units as well? I presume the direction is always written as positive in the outcome?
Yes, your answer is correct in magnitude and units. But direction is irrelevant--all they ask for is the speed, which is always a postive number (or zero!).
