What is the tension in the rope at the fixed support?
  • Thread starter erisedk
  • Tags
    Mechanics
In summary, there are two monkeys of masses 10kg and 8kg moving along a vertical rope. The first monkey is climbing up with an acceleration of 2m/s^2 while the second monkey is coming down with a uniform velocity of 2m/s. To find the tension in the rope at the fixed support, we need to add the tensions due to both monkeys. This is because the tensions in the rope can be different at different points due to the loads acting on it. Therefore, the total tension at the fixed support is 200 N.
erisedk
374
Two monkeys of masses 10kg and 8kg are moving along a vertical rope (There's just a single vertical rope in the diagram, attached to a fixed support (no Atwood's machine kind of thing), with two monkeys drawn on it.)
The first monkey (this monkey is above the other monkey, but obviously below the fixed support), is climbing up with an acceleration of 2m/s^2, while the second monkey is coming down with a uniform velocity of 2m/s. Find the tension in the rope at the fixed support.
So, basically, the solution says that you add the tensions due to both the monkeys, ie
T1-100=20 (from first monkey)
T2=80 (Second monkey)
Adding T1 and T2, you get 200 N.
How can the tensions possibly be different in a mass-less string at different points? And why are we adding both the tensions to get the tension at the fixed support?
The rope below the first monkey only have to take the forces due to the second one. The rope below the second monkey only has to zake its own weight (which is zero). So different tensions can be found between the points of application.
It's not that the tensions in the rope are summed up, but all the loads affecting the rope, which have to be held by the support.
Could you please expand on why we're adding the acceleration (ie, 20) to the total load, as opposed to subtracting it, since you mentioned that it's the loads affecting the rope that are being summed up?
Monkey 1 (m1) is in accelerated movement upwards of a1=2 m/s2 + the gravition (g). The load due the monkey 1 is F1 = m1 ⋅ (a1 + g) = 10 ⋅ (2 + 10) = 120 N
Monkey 2 (m1) is in non-accelerated movement (constant velocity) so a2 = 0 + the gravition (g). The load due the monkey 2 is F2 = m2 ⋅ (a2 + g) = 8 ⋅ (0 + 10) = 80 N
Below monkey 2 the tension in the rope T3 = 0
Between monkey 1 and monkey 2 the tension in the rope T2 = F2 = 80 N
Above monkey 1 the tension in the rope T1 = F1 + F2 = 120 + 80 = 200 N
stockzahn is right.
As for your question as to how tensions in different parts of the same massless rope can be different, all you need to know is that net force on every element is to be zero. If external forces act on one part, tension will change accordingly, as shown by this question.
Thanks! Got it :)
1. How do monkeys on ropes exhibit mechanics?
Monkeys on ropes exhibit mechanics through their movements and interactions with the rope. They use their weight and strength to swing, climb, and hold onto the rope, demonstrating the principles of force, motion, and balance.
2. What are some common mechanics observed in monkeys on ropes?
Some common mechanics observed in monkeys on ropes include the conservation of energy, mechanical advantage, and the use of leverage. Monkeys also demonstrate an understanding of gravity and the relationship between force and acceleration.
3. How do monkeys on ropes use their body mechanics?
Monkeys use their body mechanics to maneuver and control their movements on the rope. They use their arms and legs to grip and propel themselves, and their tails for balance. They also adjust their body position to distribute weight and maintain stability.
4. What can we learn about mechanics from studying monkeys on ropes?
Studying monkeys on ropes can teach us about the basic principles of mechanics, such as the relationship between force and motion. We can also learn about the efficiency and effectiveness of different mechanical techniques used by monkeys, which can be applied to other fields such as engineering and robotics.
5. Are there any practical applications of studying monkeys on ropes?
Yes, there are practical applications of studying monkeys on ropes. By understanding how monkeys use mechanics to navigate and interact with their environment, we can apply this knowledge to develop better tools and techniques for tasks such as rock climbing or designing prosthetics for humans.
