Mooring line for wind turbine model
A floating wind turbine model is being constructed for a wave tank experiment, requiring a suitable mooring line. The line must exhibit a linear force-elongation relationship at tensions up to 50 kg, minimal elongation over time, flexibility for a pulley system, and corrosion resistance. Options under consideration include monofilament steel wire, carbon fiber wire, and fishing line. Suggestions from participants include using Spectra fibers or thin wire rope commonly found in fishing tackle shops. The discussion focuses on finding the optimal material for the mooring line to meet these specific requirements.
anders.sparen
Hello,
I am construction a floating wind turbine model which is going to be used in a wave tank experiment this fall. Currently I'm looking for a mooring line for this model.
The line will go from the wind turbin down to the bassin floor, where it will go through a pulley and back up to the surface. Above water it will be connected to a spring system which models the stiffness of the mooring line.
The mooring line has should have the following characteristics:
- Approximately linear relationship between force and elongation in the area 0-50 kg tension.
- Very little or none elongation with time for a given force (low creep?)
- Be able to be bended of in a pulley of unknown size, angle approximately 100 degrees.
- Good against corrosion.
Does anyone have any tips?
I am currently considering:
- monofilament steel wire
- Carbon fiber wire
- Fishing line
Best regards
Anders S
Specta fibers might work well.
Or maybe a thin wire rope like that sold on fishing tackle shops for leader material.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
10K
11K
