Vectors Help: Solving Two Problems
  • Thread starter Thread starter NIZBIT
    Vector
The discussion revolves around two vector problems that the user is struggling to solve. The first problem involves calculating the resultant distance and angle after Bob walks and jogs in various directions, with suggestions to draw vectors and resolve them graphically. The second problem concerns a flock of ducks needing to fly at an angle to counteract a westward wind while migrating south, with advice to use vector equations to find the correct heading. The user is experiencing difficulties with rounding and significant figures in their calculations. Clarification is needed on the specific direction of Bob's final walk to accurately determine the resultant distance.
NIZBIT
I am stuck on two problems and I keep getting them wrong. Its been a while since I did vectors so I'm a little rusty.
1. Bob walks 200 m south, then jogs 730 m southwest, then walks 200 m in a direction 27.0 degrees east of north. What is the distance and angle?
2. A flock of ducks is trying to migrate south for the winter, but they keep being blown off course by a wind blowing from the west at 6.0m/s. A wise elder duck finally realizes that the solution is to fly at an angle to the wind. If the ducks can fly at 8.0m/s relative to the air, what direction should they head in order to move directly south?
I know these are probably simple, but I'm banging my head on these two. For problem 1, I tried graphically to resolve the vectors using tip to tail but my apporach. Promlem 2 if the wind is blowing from the west so its 6m/s east?
Yes, draw the vectors and everything should be prefectly clear.
\vec{v}_{ducks, total}=\vec{v}_{wind}+\vec{v}_{ducks,relative to wind}. The wind vector is known, as is the direction of the final velocity vector of the ducks. Just use the vector equation and the known magnitudes. Solve graphically. :smile:
I'm getting a rounding or sig fig error on #1. For the distance I got 710.7 so 711?
I didn't notice this earlier, but you did not specify in what direction he walks 'east of north'. You can go 'up' or 'down' from there, and depending on that, you get two solutions; one around 800 m, and the other around 1000 m.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
