Find Time for Motion Homework: Equations, Solutions, & Examples
  • Thread starter Thread starter Troubadour
    Motion Time
The discussion revolves around a physics homework problem involving a train's motion, where the train accelerates, travels at a constant speed, and then decelerates. The user is trying to determine the total time taken for the journey based on the given equations of motion but struggles to express the time intervals in terms of a single variable. Participants emphasize the importance of showing work for effective assistance and suggest using ASCII symbols if LaTeX is challenging. The conversation highlights the need for clarity in problem-solving to facilitate better guidance. Overall, the focus is on understanding motion equations and their application in calculating time.
Troubadour
The speed of a train increases at a constant rate α from zero to v, and remains constant for an interval, and finally decreases to zero at a constant rate β. If L be the total distance traveled, then the total time taken is-
(a) (L/v) + (v/2) [(1/α) + (1/β)
(b) (L/v) + (2/v) [(1/α) + (1/β)
(c) (L/v) + (2v) [(1/α) + (1/β)
(d) (L/v) + (1/v) [(1/α) + (1/β)
v = u + at
s = ut + (1/2)at2
2as= v2 - u2
I don't really know how to type in LaTEX so I can't show you the exact working. In short, I found the time during acceleration, time during constant speed and time during retardation. But I don't know how to write them in terms of one variable so that I can add them together.
We won't know how to help you if you don't show your work. If LaTeX is not your thing you can use regular ascii and the symbols from the table accessed via the Σ icon, and use the x2 and x2 icons to create subscripts or superscripts.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
