Is Velocity Zero if Displacement is Zero?
But here, the average velocity over the entire trip is zero. In summary, James walked 2 km away from home in 30 minutes, then returned home in another 30 minutes. His average speed was 1.11 m/s and his average velocity was 0 m/s due to his displacement being 0 km.
at94official
50
James walks 2 km away from home in 30 minutes. He then turns around
and walks back home along the same path, also in 30 minutes. Calculate James’
average speed and average velocity.
My answer:
s = d / t
= 4000m / 3600s
= 1,11 m.s -1
v = Δx / Δt
= 0 m / 3600 s
= 0 m.s-1I'm just confuse about one part in velocity, so if your displacement is 0 the velocity is always 0? yeah?
The average velocity is then zero. There is also the concept of instantaneous velocity which applies at any given instant anywhere along the path.
What is "motion in one dimension"?
Motion in one dimension refers to the movement of an object along a straight line or path. This means that the object is only moving in one direction, either forward or backward.
What is the difference between distance and displacement?
Distance is the total length traveled by an object, while displacement is the shortest distance between the object's starting point and ending point. Distance is a scalar quantity, while displacement is a vector quantity.
What is the difference between speed and velocity?
Speed is the rate at which an object moves, while velocity is the rate at which an object changes its position in a specific direction. Speed is a scalar quantity, while velocity is a vector quantity.
What is the equation for calculating average speed?
The equation for calculating average speed is:
Average speed = total distance traveled / total time taken
What is acceleration?
Acceleration is the rate at which an object changes its velocity. It can be calculated by dividing the change in velocity by the change in time. Acceleration can be positive (speeding up) or negative (slowing down) depending on the direction of the change in velocity.
20K
17K
