Motion of Charged Particles in E&B Fields
12 replies · 2K views
PumpkinCougar95
Problem Statement: A system consists of a long cylindrical anode of radius a and a coaxial cylindrical cathode of radius b (b < a). A filament located along the axis of the system carries a heating current I producing a magnetic field in the surrounding space. Find the least potential difference between the cathode and anode at which the thermal electrons leaving the cathode without initial velocity start reaching the anode.
F = m dv/dt = q( E + v x B )
What I have tried: https://drive.google.com/open?id=1sLIz7ZsUwS0wkBW4iGEXWJBrxCenahKs
In the last step, I forgot to put a square on the log() term. But what I have written is given as the correct answer. I do not understand what I have done wrong. Help, please?
The answer I got is not correct. Apart from that, I don't really understand.
In your first post you said that what you had written gives the correct answer. Here you are saying you did not get the correct answer. So, I'm a little confused.
Your answer in the first post looks correct to me (except for possibly a sign issue).
Oh sorry for the misunderstanding. In the last step I wrote, you can see I missed a square sign on the log() term from my previous line. What I meant was that the correct answer doesn't have a square on the log() term.
But here it doesn't have a square...
https://drive.google.com/open?id=150Xo6D7BZjyYOkX3oiMmyqtbWZdhIVGA
https://drive.google.com/open?id=1RFOoNg3Pk5N35cuZ9o_Wv5ugz3aMfgIW
In deriving the second equation from the first equation above, you should get a square on the log term.
[EDIT: The first equation above should have a square on the log in the second term on the right side. The answer for V in the second equation should also have a square on the log.]
Yes, i got it. Thanks for your help!
I think you would only need to solve the Fz equation to get the answer, so it doesn't make any difference whether you use cylindrical or cartesian coordinates.
I have no idea on how to solve these equations completely.
But if you know ##V_z## you can apply conservation of energy between r=a and r=b. See my first post.
