Motion on Incline Problem: Find 1st Mark in 2.5s
In summary, the conversation discusses a problem involving a ball rolling down an inclined plane and marking distances at 2.5 second intervals. The first mark is 1.5m from the starting point, and the location of the fourth mark is being questioned. The speaker has made a velocity vs. time chart and determined the velocity to be 0.6, but their answer was deemed incorrect. They mention the ball's acceleration and assume the velocity remains constant.
Cole07
106
problem: A ball is allowed to roll from rest down an inclined plane, and the distances are marked every 2.5s. if the second mark is made 1.5m from the starting point, where is the first mark?
where is the fourth mark?
well i made a velocity vs. t chart and the velocity of it is 0.6 then ifound the velocity of ech number on my graph but iwas told my answer was wrong. can you help me please.
well the ball is going to accelerate as it rolls down the plane. it sounds like ur assumin the velocity stays the same
Based on the given information, we can use the equation d=1/2at^2 to find the distance traveled by the ball in 2.5s. Since the ball starts from rest, its initial velocity (u) is 0. Therefore, we can rewrite the equation as d=ut+1/2at^2. Plugging in the values, we get d=0+(1/2)(9.8m/s^2)(2.5s)^2=30.625m.
This means that the first mark is 30.625m from the starting point.
To find the fourth mark, we can use the same equation with a different value for t. In this case, t=10s (since the fourth mark is made after 10s). So, d=0+(1/2)(9.8m/s^2)(10s)^2=245m.
Therefore, the fourth mark is 245m from the starting point.
It is important to note that this solution assumes that the ball is rolling without any external forces (such as friction) acting on it. If there are any other factors involved, the results may vary. It is also possible that there may be a mistake in the given information or in the calculations. I would suggest double-checking the values and equations used to ensure accuracy.
1. What is the motion on incline problem?
The motion on incline problem is a physics problem that involves determining the motion of an object on a sloped surface. This problem typically involves finding the distance, velocity, and acceleration of the object as it moves down the incline.
2. How do you solve the motion on incline problem?
The motion on incline problem can be solved by using the principles of kinematics, such as the equations of motion and the concepts of displacement, velocity, and acceleration. It is also important to consider the effects of gravity and the angle of the incline on the motion of the object.
3. What is the significance of finding the 1st mark in 2.5 seconds?
In this context, the 1st mark refers to the position of the object after 2.5 seconds of motion on the incline. This value is significant because it allows us to determine the initial velocity of the object and solve for other parameters, such as the acceleration and distance traveled.
4. What are the key factors to consider when solving the motion on incline problem?
When solving the motion on incline problem, it is important to consider the angle of the incline, the force of gravity, the initial velocity of the object, and the coefficient of friction between the object and the incline. These factors will affect the motion of the object and must be taken into account in the calculations.
5. What are some real-world applications of the motion on incline problem?
The motion on incline problem has various real-world applications, such as calculating the trajectory of a ball rolling down a ramp, determining the braking distance of a car on a sloped road, or predicting the motion of a skier going down a slope. It is also relevant in fields such as engineering, sports science, and transportation.
